Need help with ez go golf cart governor adjustment
NY
A friend has a 1993 ez go golf cart gtx-804 with a 295cc robin engine. There is a cable that goes from the accelerator to the transmission area then there is a bunch of solid linkages that go from there and connect to the carburetor. I am looking for any information on factory specs for the solid linkage adjustments.
mo
What you want is carb to be all the way open when accelerator is fully pushed.also make sure carb is totally closed when accelerator is lifted.also make sure cable isn't sticking.
mo
The adjustments you need to make to get this result will vary. Depending on how old cables are and how stretched springs are. Old golf carts are way different than newer cars.
