Need help with Donaldson filter
Parma - Italy
Hi All, I'm currently using this Donaldson oil filter #P551201: is there anyone that can give me the corresponding (same features and dimensions) oil filter with synthetic media part number? Thanks in advance.
Wolf_Tm250
Parma - Italy
Originally Posted By: OnTheWaterfront
Mobil 1: M1-204 Royal Purple: 20-253 Purolator: PL14670
Sorry... I meant corresponding Donaldson oil filter with synthetic media... Thanks
Wolf_Tm250
Parma - Italy
What is the application?
Race car with custom mount. Thread 3/4 "-16 UNF Outer Ø (mm) 97 Height (mm) 101 Anti-drain valve Bypass pressure 2.5 bar Thanks
Wolf_Tm250
Parma - Italy
If you can fit an FL-1A length filter, the P169071 Donaldson is the one you want.
Ah, see... still have to check if it could fit, but I just saw the relief valve setting is too low, as it is only 8-11 PSI (0.60-0.80 BAR)... Thanks
Wolf_Tm250
Parma - Italy
Why do you need such a high relief pressure?
Because I have a very high pressure oil pump, and very high cold idle oil pressure, so I want to avoid any bypass. Anyway that filter is too long... Thanks!
OVERKILL
$100 Site Donor 2021
Ontario, Canada
It is going to bypass regardless. Remember, bypass valve actuation is based on pressure differential, not system pressure. When the oil is cold and thick, the media is simply not going to be able to keep up. And forcing a high bypass pressure just means the engine may starve for oil a split second longer while waiting for the bypass to open. Sucks that it is too long frown It is a very good filter.
Wolf_Tm250
Parma - Italy
Yes, I do understand this... but the idea of a 0.6 bar bypass terrorize me too much... doesn't make me feel safe... Thanks
