It sort of depends on how badly gummed up it is. I have had success running a cleaner straight into the system, full strength. Only run it for a few minutes and immediately run gas in it to displace all of the cleaner. I consider this to be a Mickey Mouse answer, but it sometimes works well enough. If that doesn't do what you need, then take the carbs apart.
Actually, sometimes you can clean it up with some carb spray. Not just down the throat, but some into the bowl vent so it will mix with the bowl. It also sometimes helps to block the airflow with the palm of your hand and immediately release so that the venturi pressure wave is disrupted to help pull junk the rest of the way through the jets.
