Need building solution for covered patio addition
Have a 18x8 patio addition, that I would like to cover, and attach to the house. Had a couple guys look at it, and they did not want to tackle it due to the
"roof transition". Enclosed are some photos, any ideas, recommendations, advice, consult other good websites, please feel free to let me know.
Thank you very much for any suggestions you may have.
First post on an oil forum and you ask a construction question. Interesting!
I see a couple solutions. I would go freestanding because HERE at least, no permit needed. I would use 6x6 posts for visual appeal, but of course you would have posts. But maybe only one necessary in deck area. This also depends on what you are after in the end.
What area?
As @AZjeff suggested, you could do a one of the modular aluminum/foam roofs attached under the higher soffet, sloping downward over the deck rail, stair areas. Leaving the lower hip roof and gutter area to the left, open as is. Some of my family members have similar setups. I've had them as well. Those locking panel roof systems are incredibly strong and completely insulated.
Or take off the gutter to the left and attach directly to the fascia and have it run flat to the right. Have the high gutter slope to the right downspout. 18' might be too much span. Don't know your location and possible snow load but it looks like moss/algae on the deck and railing so maybe no snow. We've never had one of these patio covers but others in the family have and they've been fine.
Good idea, Jeff. I’m in Ohio, and we do get a 6-8” snowfall, 1-2 times per winter. Will see what the Amish think, lol. That definitely helps, thank you.
Step 1 don’t fully or firmly attach to the house (it must be able to break away)
Step 2 have independent supports by the house wall
Step 3 WAY OVERDUE water transitions , have an excessive amount of eave, expect that the slope will never be adequate no matter how much $$$ you spend , use a rubber roof or a single spray on that is fully waterproof even if water sits on it.
Step 4, use metal anywhere you can, if you go against better advice and use wood, use outdoor treated wood with thomsons waterseal especially in the roof and expect squirrels and other creatures will try to destroy your home using this area as a jumping pad.
Step 5, most important avoid having this be an insulated year round area if humanly possible
Yes myself and relatives have ignored one or more of the above resulting up to and including needing to later raise the deck or damage to the house main structure even though the thing was fully overbuilt past code)
Everything that can go wrong will and doing structural changes to mount into the house is extraordinarily bad if anything out of the ordinary happens(better to be out a deck than plow your main roof down after storm/tornado damage)
In the north these things are common and also always constantly a source of extreme pain and cost. Especially if the house brand new came with one from a builder.
If a contractor tells you xxxxx don’t believe them, better to overbuild it as much as possible YOURSELF unless you want a 10 year structure that becomes a boondoggle)
The contractors are correct. As a layperson short of redoing both roof lines it's a no go.
It’s not a no go but you are guaranteed to have non-recoverable storm damage down the road no matter how well it’s done and animals using it to burrow into the main structure, the slope no matter how steep is never enough to use normal shingle/construction methods.
That said, whoever designs homes with 3 overhangs in an area should be shot, homes shouldn’t meet code if they are designed that hillbilly way for aesthetics, up here that area WOULD LEAK at some point, likely invisibly making underlayment rot, total garbage design.
What about one of those metal tent structures? You may have to remove and reinstall for the winter, but it would be free standing and you can even get the bug screens. Might do the job without committing to a permanent structure. Our friends have one on their deck and its quite nice.
