Need a oil flow graph for a small block chevy
VA
If you are looking for flow to some specific area(example main & rod bearings) at a given RPM with say 10W-30 oil at 100C & 30psi pressure, I doubt you will find any meaningful info... Why??? Because bearing clearance is going to dictate what pressure would be, which is directly related to flow... Oil pump capacity also plays a roll...
