Originally Posted By: unDummy
Napa tends to have 'levels' of most parts. Avoid their cheapie parts and use the premium ones and you will be ok.
Don't be surprised if they rust quickly. Some of the OE drums are painted/coated/plated on the outside so they rust a lot slower.
In a couple weeks, new cheapie drums will look like they were pulled from a shipwreck.
You can't go wrong with OE Toyota drums, especially if you don't want to replace them again in a decade. I'd consider Toyota shoes too. Too many aftermarket shoes need riveting or pin pressing. With the OE shoes, you'll only have to worry about a couple easy to assemble clips...
+1
Napa has low, middle and high end brake shoes and drums. Avoid the low end stuff and you will be fine. Overall, I like Napa parts better than most other national chain parts. Around here at least, they seem to have more experienced/educated employees.
