Mystik JT6 #2 hi temp for ball joints
I should have said, either can be used...
but moly is preferred for slow speed pounding joints and...
no moly is preferred when bearings need to roll.
Originally Posted by luca
I wanted to double check if Mystik #2 high temp is acceptable to use in ball joints. Thanks!
I take it you already have a tube of it.? Yes, it is rated GC for wheel bearing and LB for chassis lubrication and is perfectly suitable.
Yes I have a tube of it in my gun. It's the non moly. Sounds like it'll do just fine in my new ball joints. Thanks for confirming
I use the standard JT6 for everything: Up here in Canada it's readily available at Canadian Tire, but I've never seen the moly version anywhere.
