My Walmart has dropped the Endurance for a new 20k Purolator
At Elevation
Over the last 4-5 months I’ve been reporting here that the Endurance shelf at my local Walmart has been shrinking. Today it was totally gone and replaced with a new 20k mile Purolator. I’m guessing it’s a new Walmart exclusive.
cheaper media than the wire-backed Endurance and of course they're still prone to tears and/or ADBV slit :sneaky:
I'm counting that as strike one. Since my Fram stash is running low and reports here have been indicating for quite a while that Fram made some changes. It appears not for the better since I last bought filters, so I'm on the lookout for something to change over to. I ruled Purolator out when they switched to the Puke colored Pure One filters many years ago. I was considering giving them another shot, but it looks like they might be striking out again........... ;)
Just in there yesterday, not here, at least not yet. Interesting description, not a Boss but 'perhaps' enhanced P1 media? ~$8.50 off the shelf price for the 7317 application, not bad. As I've had solid results (all c&p here) on Hondas /Nissan with the P1 PL14610/14612- US Bosch Prem. 3323, I'll give the 7317 a look.
As a related aside, I noticed they raised the price on the China made wire backed media XG Pentastar cartridge so that it's now more than the same FE (~$13) cartridge. Crazy. Also noticed more Super Tech cartridges now made like the wire backed Toyota cartridge including but not limited to the GM Ecotec engine cartridge, also US made.
Wonder if the FE filters just not selling.
Yes!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! YAY!!!!!!!!!!!!!!!!!!!!!!! Purolator for the win!!!!!!!!!!!!!!!!!!!!! :p
Perhaps we'll figure out exactly what these filters are with enough cuts. FE too expensive for consumers right now so off it goes.
Thanks @Glenda W. !!!!
I'll jump in front of ya when they start throwing rocks at you (or jump behind that shelf full of Purolators). 😬 ;) 😅
I see they are still using vague (IMO deceptive) 99% dirt holding marketing blather. Efficiency is likely low, it is rated 20k and Purolator has shown a propensity to sacrifice efficiency to get high capacity for extended OCIs. Glorified P1 or some kind of hybrid with the Boss?
Very interesting find, thanks for posting. Can’t wait to see one cut!
"Exceeds OE Performance" No worse than an OE filter & it can stay in for a lot longer. Obviously, they're making it cheaper than the Boss line since I'm not seeing any "SmartFusion" reinforced media being mentioned on the website & being a WM "Exclusive".
I’m looking forward to some c&p’s. Walmart is a big contract. Should be interesting!!
The video, one side of the box and @Glenda W. it looks like your in store picture all show louvers. Another side of the box looks like it is showing a plastic cage. Guessing that is not going to happen unless it is just select part numbers. Puro dumping the half open louvers for a plastic cage would have been an upgrade.
The one I took out of the box had louvers.
Purolator One
  • High-density Synthetic-Blend media
  • Silicon Anti-Drain back Valve
  • PTFE Oring gasket
Purolator 20k WM "Exclusive"
  • Dual Layer Synthetic-Blend Media
  • PuroSEAL gasket technology provides maximum leak protection and a secure fit under all driving conditions. (Boss also claims "PuroSEAL")
Seems this new 20k:
  • Media is a step up from the ONE but not quite as good as the Boss
  • PuroSEAL Oring gasket seems to be similar to the Boss
  • Both have Silicone ADBV
  • Assuming mostly "Made in USA"?
  • Still thinking & reading... :unsure:
