4WD
$50 site donor 2024
BiL had to trade his truck when the 4L60e started shifting bad … only got 400k from it … horrible I tell ya
I've been considering leaving mine at the tranny shop for a shift kit installation because I really want it to make 400k. I bet with the prices of new trucks it's more common than you think that people with work trucks might be doing preventative upgrades to make their truck last longer. Especially if they tow with it.LOL. Yeah taking heat for this post, but the tranny place was usually 80% GM waiting for repairs.
Bought it at 200K miles. Previous owner "drove it like a car" and I believe him. Bed and body and interior all in near top shape for its age. Told me he drove it from Houston to Illinois and back often. No reason to not believe him. He also told me oil and all other fluids were serviced "regularly" without a miss. Trans fluid at time of purchase looked pretty good.I'd be interested in the OP's history of servicing this tranny, fluid/filter changes and what type of fluid used.
Wouldn't it be the weakest link on every car going out first?Because they last so long that the weakest link, the tranny has to finally go out?
For many yes, but not necessarily the majority. Lots of cars have steering and suspension issues (especially with electric power steering), severe rust problems, electrical problems, water pump failure (Ford 3.5), turbo failure, or a combination of all of those things. My girlfriend's Sonata is known for engine rod bearing failure, starter failure (located under the intake manifold!) a number of other less severe things but not really known for transmission failure.Wouldn't it be the weakest link on every car going out first?
I kept mine in 3rd most of the time for years before I bought it. The hilly terrain it would always be downshifting (4.8 with 3.42 gears and a heavy load in the box) if I left it in overdrive. It runs at 2200 rpm in 3rd on the country roads or 1500 in overdrive. The one time I drove it with nothing in the back (before cab corners and rocker panels) it could be driven in 4th without downshifting all the time.I tow 5k lbs with my 2003 avy 1500 4 x 4.
I run in 3rd, 3.73 gears. R.p.m at 65 to 70 around 3k keep it out of O.D and have a added tranny cooler.
I thought it would be a Nissan/Subaru CVT...
Which is amazing since you were tardy changing ATF … but flipped it slowly and managed the buildup well …While I do agree with you on this....
I have 334,600 miles on my 08 Nissan Altima VQ with a CVT. Granted 95%+ open highway miles extremely helpful though.
And the easiest to build into a performance unit … bolted to a serious GM crate mate … Walla !GM transmissions are by far the cheapest units to rebuild in the industry, People are more apt to have a GM transmission rebuilt because of that.
Used GM trucks are so expensive (here anyway)......That it's more cost effective to have the trans rebuilt. This is especially true for the GMT800.
Thanks for the info. I will just leave it until it fails then. I will add a cooler and change the fluid again in the spring.I would recommend against that, The 3-4 Friction Drive Splines/Tabs are likely pretty worn by now. Any increase in pressure or changes to the 2-4 band vs 3-4 Clutch dynamic timing can & will have adverse effects to the already worn drive splines.
The band has to be hydraulically knocked off & the 3-4 clutch has to come on during the 2-3 shift. Right now it likely has a small "cut loose" in the clutch timing where it shifts......1st, 2nd, 1st, 3rd. The bold is the very short cut loose where the unit is mechanically in 1st gear.
Changing the Band/3-4 Clutch timing via a shift kit can result in a......1st, 2nd, 4th, 3rd, The bold is a small Bind/Tie-up where the Band & 3-4 Clutch are on at the same time where the unit is mechanically in 4th gear. This will only accelerate 3-4 friction drive spline wear.
Most EVERY shift kit states to increase the Band Release Orifice to .093" from the factory .086".....NEVER do that, Even on a fresh built unit with .040" Band clearance & .020" 3-4 Clutch clearance....Leave it at .086"!!! Now there are cases that you can enlarge the band release orifice but it requires a complete rework of the 3-2 downshift circuit.
The Torrington Bearing under the front carrier (Planet) is notorious for going south at @ 250,000-300,000 miles, GM redesigned the bearing for the 2007 model year.....After the 2003-2006 unit's were updated to the point they made it that far in greater numbers. People like to state GM doesn't care about products past the warranty period, Well.....GM could have easily kept the 1st design bearing without effecting their bottom line one bit.
What was the maintenance history?First time in my life, I have had a trans failure. 2004 Avalanche, 225K miles. Cha-ching!
You’re right. Most Ford and Dodge owners don’t care to fix their truck when the drivetrain craps out.I knew it was a GM product before I even clicked on it to read. Used to pass a tranny place and the place was always loaded with GM cars.
