Originally Posted By: timeau
OK, seems there is some misunderstanding here.
What the piston slap is? Roughly speaking, piston shakes in the cylinder. Why does it shake? Because engine is cold and there is a gap between piston and wall. Once heated, "feature" should gone. This is a feature, you can't and you should not try to "cure" it.
But I am 99% sure that sound that bothers you comes from valvetrain. Probably hydrolic lifters or something else, IMO.
The piston doesn't "shake" in the cylinder, but it does rock back and forth until clearances are tighter. Noise caused by the rather common Honda K-series piston slap does tend to be better masked by some oils compared with others. I don't believe that it's a viscosity thing; I think it's an additive thing.
This engine does not use hydraulic valve lifters.
