- Replace Valve Cover Gasket
- Replace Spark Plug Tube Seals
- Replace Spark Plugs
- Replace Spark Plug Wires
- Replace PCV Valve
- Clean EGR Valve and Throttle Body
- Replace Engine Coolant Temperature Sensor
- Replace Torque Axis Mount, possibly lower transaxle mount as well
- Replace Brake Fluid
- Replace Power Steering Fluid
- Replace Automatic transmission fluid and filter
- Replace Air Filter
- Replace Fuel Filter
- Check Brakes (apply anti-squeal compound, check rotors for warpage and check calipers due to rubbing noise that has returned)
- Chemically clean cooling system
- Fix window weather-stripping trim
- Fix/Resolder trunk wires
- Top-off A/C Refrigerant
- Check Cruise Control TSB
- Fix Transmission Leak
- Check Shocks, probably need to put new ones on
- Check Exhaust hangers
- Get new tires within the next 10,000 miles
- Change Engine Oil and Filter soon
Car has 93,500 miles, '96 Saturn. Anything else I should add to the list?
Thanks.
- Replace PCV Valve
Thanks.
