0w20 is close enough, 5w30 is close enough. If you are looking for an exact match for your engine you likely will be shopping for a special certification one anyways and you can't just shop by weight.
That Ford oil spec defines the grade. It even changed when Ford specified oils formulated for LSPI. I wouldn't say it's not required.It is a Ford material specification. It’s not required.
Understood, I was just going by a typical owner's manual that says:That Ford oil spec defines the grade. It even changed when Ford specified oils formulated for LSPI. I wouldn't say it's not required.
Ford WSS-M2C9C960-A1 basically says the oil has to be a 5W-20 that meets ISLAC GF-6.But neither one of them meet WSS-M2C9C960-A1?
Got ya ... yes, that statement basically mirrors what is buried within Ford WSS-M2C9C960-A1 (ie, simply a 5W-20 that meets ISLAC GF-6).Understood, I was just going by a typical owner's manual that says:
We recommend Motorcraft® motor oil for your vehicle. If Motorcraft® oil is not available, use motor oils of the recommended viscosity grade that meet API SP requirements and display the API Certification Mark for gasoline engines.
But also note they say the "recommended viscosity grade", not that grade is a stated requirement either. To me the only thing they really imply is required is the API SP license.Ford WSS-M2C9C960-A1 basically says the oil has to be a 5W-20 that meets ISLAC GF-6.
No other viscosity (even if it's ISLAC GF-6) will meet that spec, because the spec is locked into specifying a 5W-20 grade oil.
Of course ... we all know that basically every vehicle OM you can find says "recommended" and not "required" when it comes to the viscosity call-out.But also note they say the "recommended viscosity grade", not that grade is a stated requirement either. To me the only thing they really imply is required is the API SP license.
That's what the 0w40 is for.Running a thinner oil at higher temperatures.. I'm leaving for the Carolinas, in about 2 months. So it's going to be a lot of highway driving..
Are you proud of being uninformed? If not, maybe you should bring yourself up-to-date so that you can provide accurate information. There are a lot of new members seeking assistance and providing outdated information is doing this site a disservice.I have no idea what all those numbers and letters mean. I have always chosen my oil as 5WXX, 10WXX, or 0WXX.
Sometimes 20W50, 70 wt., and 30 wt.
I have never needed to know what those numbers mean. My trucks engine runs on whatever I feel like adding to it.Are you proud of being uninformed? If not, maybe you should bring yourself up-to-date so that you can provide accurate information. There are a lot of new members seeking assistance and providing outdated information is doing this site a disservice.
Lubrication requirements have evolved significantly since your truck’s engine was designed. If you are unfamiliar with the specification or the platform posted, please be responsible and do your homework before posting. Oil data sheets and owner’s manuals are easily available from their respective manufacturer’s websites. Offering incorrect information based on your own outdated experiences is an irresponsible practice on your part.I have never needed to know what those numbers mean. My trucks engine runs on whatever I feel like adding to it.
You don't have to get all twisted out of shape. Instead, you can be the one to start teaching me. Or, would you like to just keep putting me down?
I think you need to go read my reply to your PM and do as the last sentence states!Lubrication requirements have evolved significantly since your truck’s engine was designed. If you are unfamiliar with the specification or the platform posted, please be responsible and do your homework before posting. Oil data sheets and owner’s manuals are easily available from their respective manufacturer’s websites. Offering incorrect information based on your own outdated experiences is an irresponsible practice on your part.
