Originally Posted By: JDW
Originally Posted By: sayjac
Originally Posted By: bigt61
Leave the poor guy alone, doubtful he could make any money selling those - it looks expensive to me.
Just buy a Jegs.
http://www.amazon.com/JEGS-Performance-Products-Filter-Cutting/dp/B007VR8C0U
The Jegs 'appears' identical to the cutter sold at Summit Racing linked below. It too says filters up to 5.5" diameter. However owning the Summit cutter, 3" and less dia. filters hit the cross bar and not the guide wheels, as shown here. So unless Jegs has moved the guide wheels closer it doesn't work well (smoothly) for 3" or less diameter filters. The tell tale sign is paint gone from cross bar between the guide wheels on the cutter.
One member retro fit the Summit with bigger wheels to make it work for smaller filters.
http://www.summitracing.com/parts/sum-900510/overview/
I have the same and works very well
So you are saying the guide wheels on the Jegs make contact with oil filters of 3" diameter and smaller? Or the Jegs works well for your applications?
If you would perhaps you could take a measurement between the center of the two studs on the cross bar and post it so I can compare the distance to the Summit cutter. If Jegs has moved the wheels closer then they have addressed the main issue with the Summit, ie., cutting smaller filters.
Below is a pic with the link to the thread showing the modification of the Summit to make it cut smaller filters.
http://www.bobistheoilguy.com/forums/ubb...ter#Post2749690
Just buy a Jegs.
