Hello:
I special ordered this car from the factory because I didn't want a sunroof, taking possession on February 2003. The car has never been driven in rain or on wet roads. It's never spent a single day parked outside for more than 15 minutes, nor has it spent a single night parked outside. Basically, the only time it's outside is when it's being driven.
Two or three times a year I hand wash the entire undercarriage using a wool wash mitt. I don't use harsh chemicals and I'd never dream of using a power washer!
I do 100% of my own work. Since taking possession the car has not been serviced or worked on my anyone except me. When getting tires I remove the wheels and take them "loose" to the tire shop.
The car has 83K miles on it and it's been flawless. Even though the car is pampered it gets "driven".
Anyway, I just thought you might enjoy seeing a meticulously maintained California car. Once again, these pictures were taken in April 2014. These pictures were taken when the car had 83K miles on it!
Scott
List of mods:
BBS CH 19x8.5, 35mm offset
Bridgestone RE-11 Y-rated 235/35-19
H&R Springs
Bilstein Sport Struts/Shocks, E36 M3 Versions On Rear
BMW Motorsport Front Strut Tower Reinforcement Plates
Rogue Engineering Rear Shock Mounts
H&R Sport Adjustable Anti-Roll Bars, 27mm front, 21mm Rear
Turner Motorsports Adjustable, Ball Jointed Front Anti-Roll Bar Endlinks
Mason Engineering Adjustable, Spherical Bearing Rear Anti-Roll Bar Endlinks
Mason Engineering Front Strut Brace
BMW Motorsport ZHP Front Control Arms
BMW M3 Engine Mounts
BMW M3 Transmission Mounts
Lemforder 66mm Front Control Arm Bushings
BMW M3 Rear Control Arm Bushings
Turner Motorsports Rear Control Arm Bushing Limiters
BMW M3 Spherical Bearing Rear Lower/Outer Control Arm Bushings
BMW Group N Spherical Bearing Rear/Upper Control Arm Bushings
Stoptech Stainless Steel Brake Lines F/R
BMW Motorsport Cross-drilled, Fully Floating Front Brake Rotors
Jurid Sport Front Brake Pads
BMW M3 Rear Brake Pads
Turner Motorsports Brass Brake Caliper Bushings
Borla Catback Stainless Steel Exhaust
Meyle Heavy Duty Rear Differential Mounts
BMW ZHP Finned Rear Differential Cover/Cooler
BMW ZHP Shift Knob
B&M Short Shift Kit
UUC Stainless Steel, Weighted Shift Rod
Mason Engineering Quick Shift Geometry Clutch Pedal Arm
Stewart Engineering Water Pump
Rogue Engineering Underdrive Pulley Set
BMW M3 Trunk Lid Spoiler Lip
BMW Motorsport Alcantara Steering Wheel
Scott
List of mods:
H&R Springs
BMW ZHP Shift Knob
B&M Short Shift Kit
