Originally Posted By: unDummy
Did you do a battery disconnect yet?
Have you doublechecked the ATF level HOT, on a level surface, in park, while the vehicle is running?
Oops, forgot to answer your other questions. No, I haven't done a battery disconnect--don't wanna do that because I don't have enough information about that procedure (like what it's suppose to do, and what other things it might affect). Also, earlier you stated, that you "doubt a battery disconnect will clear out the adaptive programming."
Yes, I've checked the ATF level numerous times while it's hot, on a level surface, in park, with the vehicle still running, after moving the shift selector through all positions. The ATF level is fine. No leaking is happening.
I hope there's a date code on the new bottles of T-IV I get from the dealership. Anyone know if the code is read just like the date code on the M1 bottles, since both M1 and T-IV are made by ExxonMobil.
