My First Timing Chain
At 5k miles a year, the chain should last you at least 50 years if you change the oil occasionally. The timing chain won't be the problem that sends the new Lexus to the scrap heap. You'll have to find something else to worry about.
What does the OM say the OCI is? Not sure why if it is 10K, you wouldn't run 10K
OM calls for 12/10,000 for normal driving and 6/5,000 for “special” operating conditions. My driving will be somewhere in between. Mostly short tripping but above 32 degrees. Time, not mileage, will control my OCI...most likely once per year will do the trick.
