1991 Plymouth Acclaim, 134,000 miles. After a 60 mile interstate drive, get into the city, and reached a traffic light. Go to start moving again, get to 20-25mph, then the car just dies. I was kinda low on gas (1/8 tank), so I thought I had just run out. Since I have never run out on this car, I am not familiar with how it behaves.
So, I managed to coast into the gas station at the intersection, and put a little over 4 gallons of gas in, and then try to start it. Weird thing is, the gas gauge does not seem to register what I had just put in. So, I give it a few minutes, and try again. At this point, the gauge has registered, and I try again. Still not starting, I think I have flooded the car (is that even possible with a TBI system?). So, I give it another 5 minutes, and try again. Still getting nothing, I remember that I can access the SBEC Computer with the key twists. So, I get a code 11, and a code 12. End up getting towed home (65 miles).
Code 11 reads: No Distributor reference signal detected during engine cranking. Check the circuit between the distributor and the SMEC/SBEC.
Code 12 reads: Problem with stand-by memory circuit. Direct battery input to controller disconnected within the last 50 ignition key-ons.
The only problem that I had been aware of was the alternator doing it's occasional squeaking thing. So, at this point, that is what I suspect. I will be taking the alternator off and taking it to be tested.
Any other suggestions? Where should I start? The car has had a tuneup within the last 10,000 miles, has been running really well. The only recent change is that is has been seeing a lot more highway miles recently since I got it. Please help!!
