Hey guys.......I changed my oil today. I drained the ST 10W40 I was using in my ARX rinse cycle and installed M1 15W50 with my own brew of Valvoline Engine Protector and Schaeffer's #132. I mixed the two additives and added 300-350ml of the mix to the 15W50. Check out the mix here.
Well, the piston slap and engine noise is still there. I was hoping the heavier weight oil would dampen the noise a bit, but no luck. I will be analysing this brew in about 4k miles, which at the rate I've been driving lately, won't take more than 4 months.
I'm looking for reduced wear, noise reduction (that didn't happen
), gas mileage (more, less, same?), TBN retention and overall benefits (if any) of this mix.
Now, I know I'm not a chemist, but after seeing lots of evidence here, I believe the additives (which are all the same kind and compatible) won't clash with each other and trash my engine.
On a different note....when I pulled the plug to drain the old oil, there was a small metal chip on the magnet. It was very tiny (much smaller than a pinhead), but nevertheless had me scared. Anyone have any idea where it came from (piston rings??)
Comments are welcomed!
Rick
Rick
