So I'm probably going to do the gear oil in my Mustang at some point this winter. Its a basic Ford 8.8 with the trac-lok, although I did upgrade it to the carbon fiber clutch packs a number of years ago. Never had any issues with basic gear lube and the motorcraft additive. About two years ago I had a very good local shop throw some used 3.73 gears in it for me. They did a fine job but advised they were unable to eliminate whine being used gears and all. This is fine, its a weekend car with decent exhaust and a loud stereo and a little whine is fine. That said, what would be the best option for gear oil to reduce this noise? Thinking XXw-140 most likely, and I'll likely stick to dino/mineral oil since this is primarily a fair weather vehicle... Will it even matter much, or just stick with whatever 8xW-140 I can find locally? Sometimes this car does see late season use if road salt hasn't come out yet, whats the lowest temp such a heavy gear oil is good for?
