I have been searching this board for a while and the amount of good information is overwhelming. The more I learn, the less I seem to know. I have a question about the best commonly available oil (Redline, Amsoil, and Royal Purple aren't) for a dual purpose car. It is a SBC with 150 nitrous shot that does spend some time on the street. Max rpm is 7000, cruise rpm is 3000 at 55. Horsepower using several calculators is around 500 motor and 670 on nitrous. Used for drag racing on weekends. Currently I run Castrol 20W-50 which is a pretty good conventional oil from what I have read here. I tried Mobil 1 in the past and had constant problems with AC Delco filters leaking. Went back to heavier weight conventional because I read somewhere that a heavier oil tends to have a cushioning effect on the bearings under extreme load and all I could find in Mobil was 10W-30. I am mainly looking for the maximum protection for roller lifters and bearings and not necessairly for the absolute last horsepower like a thinner oil would give. I am worried about a straight 50 weight because I do drive the car on the street some in the winter even though I do let it warm up some and keep rpm's low (around 2000) for the first 10 miles or so. But on the straight weights side I have read an article (years ago) that said a straight weight was better because the viscocity modifiers added to make multi-vis offer no lubrication qualities. I think the Rotella oils would be pretty good in my application due to the environment they were designed for but am worried about the extremely high detergent package. Sorry for the long post, I am confused about the little bit of knowledge I have on the oil subject (which could be all wrong). One fun thing though, the oil filter knowledge I gained here let me prove a Chevrolet parts man wrong, he couldn't believe the lowly SuperTech's were made by the same company as his beloved Duraguard Silver $5.99 filters. So I cut them both open and brought them to him. Then he got quiet and wouldn't talk to me anymore. Great fun. Thanks, Clay
