Originally Posted By: Kira
I agree. But do a drain & fill first THEN go straight into your cooling line pump-out.
This way the transmission will be sucking up nothing but clean fluid. You won't be adding clean fluid to a half emptied sump.
EXAMPLE: Pump outs usually recommend pumping out 2 quarts-shut off engine-replace the 2 quarts-restart engine and pump out 2 more-shut off engine-replace the 2 quarts etc. This is recommended so you don't suck ait into the system.
In my case the sump holds 4 quarts. I'd be pumping out 2 and adding 2 new quarts to dirty fluid.
Starting with a fresh sump makes it a more efficient process.
The argument against wrestling with stuck cooling line fittings wasn't mentioned. If things are super crusty and old, a succession of less efficient drain & fills can make sense.
I used to do this on several of my cars. I had added a Magnefine trans filter in the cooler lines so it made it easier. Over time, I felt that just doing the drain/fill a couple of times (with ~100 miles in between) would be fine.
What ever you do, NEVER let the trans pump run out of fluid while running (I was super careful about that) if doing the cooler line method.
FWIW: There are some good arguments for doing the simple 1x drain/fill to reduce the chance of "shocking" the tranny with detergents and causing debris to come loose and plug up some fine mesh screens. I personally was a victim of the Trans-Flush machine and their special cleaners doing just that. Within a couple of weeks, the transmission died an untimely death and had to be rebuilt. NOT fun.
FWIW2: Some cars also want an internal ECU (TCM?) counter reset when you totally change out their fluid (Volvo's for example). Makes a big difference in shift quality.
