I am comparing FP60 and Lucas UCL for MPG increases. It’s not a perfect experiment, but it is some real world data with as little variables as I could achieve under normal circumstances. Vehicle is a 1993 Mazda MX6 2.0L DOHC 5spd, in good tune. EPA rated 26/34. Fuel tank capacity is 15.5 gallons. Treatment rate is 1oz/5gal except for one tank of UCL which is noted at 3oz/10gal rate. If the previous tank did not contain any of the same additive, 3oz was added to get the correct rate. If a previous tank DID contain that additive, it was added at ~2.5oz, as fill-ups were generally around 12gal. Tires were kept at 40psi. 6 tanks were used for the average MPG for FP and UCL, one sole highway mile tank of FP60 was not used (34.75mpg). 9 tanks were used for the average MPG with no additives. You can see that Shell gas was used almost exclusively (5% rebate) and also note that the ounces of additive was also accounted for when calculating MPG.
Now the cost analysis. The average $/gal of gas during this experiment was $2.596. Using $28/gal for UCL with tax comes out to $30.17. Using the cost of FP60, plus shipping, but with no tax and at the old price it comes out to $36.21/gal. When using these products at 1oz/5gal, the cost equates to an increase of 1.82% per 1 gallon of gas for UCL and 2.18% per gal for FP60, or $0.71 and $0.85 per tank, respectively. Using an avg MPG of 31.12, UCL must increase MPG by 0.57 to break even and FP60 by 0.68. UCL increased MPG by 1.10 or 3.53% and FP by 0.61 or 1.95%. FP60 basically pays for itself. Lucas UCL seems to be actually saving me money. I look forward to trying the new FP3000.
Disclaimer: this test was not controlled and the results are applicable to my car and my driving conditions only. Your mileage may vary.
In case the picture links go down in the future: the MPG averages for no adds, UCL and FP are 31.12, 32.22, and 31.73.
