Just did my annual lawn mower oil change. Dumped out the old 30w oil and it poured out like water. Smelled like gas too. It's a Honda GVC160 engine. Otherwise it works perfect. Is it normal for these engines to dilute the oil?
You can do that too.Do you turn off the gas when the engine is not running?
No. I'll start doing that. ThanksDo you turn off the gas when the engine is not running?
This is a common problem with Honda carburetors. Unfortunately, there isn't a "fix" for it. The problem is that the seat is part of the carburetor body and is not serviceable. Pitting and wear from use cause it to leak and replacing the viton tipped needle valve doesn't help. The ONLY way to fix this problem is to replace the carburetor. They are VERY cheap on eBay.You may want to check out the carb , float/needle may not be seating and it's dumping fuel into the engine. Fill the fuel to the top and see if it goes down sitting for a few days.
Shouldn't have to if the carb is in working order.Do you turn off the gas when the engine is not running?
RTV silicone will fix that.....Also, when I took the carb off my mower for other reasons, the intake gasket tore easily as it was quite old so you may need to prepare accordingly.
Bought a new gasket on Amazon for $4.55 so i would rather go that route.RTV silicone will fix that.....
That's about what a sheet of gasket mat'l cost. I have about 3/4 of a sheet left after 20 yrs. Main reason is that I can finish the job without a 'go back'Bought a new gasket on Amazon for $4.55 so i would rather go that route.
This^You may want to check out the carb , float/needle may not be seating and it's dumping fuel into the engine. Fill the fuel to the top and see if it goes down sitting for a few days.
In theory, but all it takes is one little grain of sand or a particle of something to get lodged in the needle valve and keep it from sealing. I've even seen part of the rubber fuel line get eaten away by the fuel and lodge itself into the valve, and it filled the entire engine full of fuel on a Briggs V-Twin. It was hydro-locked solid, all from an aging fuel line, and the fuel not being turned off.Shouldn't have to if the carb is in working order.
