I'm putting this Motul analysis up to start at a low mileage baseline but will be leaving the oil in for probably 10,000 kms or more with other periodic analysis added. The oil is Motul 8100 ETech Lite 0W-30 with 2500kms in a Nissan 2007 Pathfinder V6 VQ40 engine with 33500 kms, no top ups as the engine doesn't use oil. The oil filter is a Purolator Pure 1 and air filter is OEM paper. The driving is mainly normal summer stop and go city and freeway with no towing or roof rack. Truck fuel mileage is about 26 mpg using some hypermiling and just driving slow and easy.
The engineer who does the analysis still doesn't like the amounts of silicon in the Pathfinder engine and why he flagged the oil condition as abnormal, but from reading these Nissan engines show some silicon from seals, a couple more oil analysis should tell a story. The coolant in the truck only contains 46 ppm of silicon and stays at the same level so I don't think silicon levels are from coolant, but if any have other comments please post them.
