UOA by Blackstone and oil was in use December 23rd to March 6th.
I was pleasantly surprised with this UOA because I suspected that oil with a viscosity of 9.9 cst’s at 100C would shear to a 20 weight. I switched to the Motul because I was having high fuel dilution during the winter due to my short daily trips of five miles each way.
I was about ¼ of a quart low when I sampled this so I guess overall usage was about ½ quart in 6k miles. I’ll probably go with GC for my summer run since I have five quarts of it. I like the results with Motul, but shipping is expensive! I’ll run this to 7 or 7.5k max because I still have 9,000 miles left on my powertrain warranty.
Question about the properties. The viscosity and flashpoint “should be” numbers are different between GC and Motul (both posted in brackets). Why is that? Anything to do with typical 0W30’s or GC being ACEA A3?
Current; gold GC @ 7,000; gold GC @ 7,478; gold GC @ 6,144; green GC @ 5,930; M1 5W30 @ 5,774.
Code:
Equipment make: Subaru
Equipment model: 2.5L Turbo
Oil use interval: 5,900
Oil type & Grade: Motul 8100 Eco-nergy 5W30
Make-up oil added: .25 qts.
Miles on unit: 59,650
Air filter: OEM
Oil filter: OEM
Dennis: Sodium dropped again, and wear looks terrific.
The TBN read 4.8, still plenty of active additive left
in the oil. We’re glad to see that you haven’t changed
this oil yet. It still has plenty of life left in it.
No fuel or antifreeze found. Add another 2,000 or 3,000
and check back. If wear still reads low, you may not
even need to change it at that point.
Aluminum 4 5 4 4 4 6
Chromium 1 1 1 1 1 1
Iron 11 12 16 11 10 15
Copper 6 8 7 10 6 20
Lead 2 3 3 3 2 2
Tin 0 1 0 1 0 0
Molybdenum 3 2 9 4 12 63
Nickel 0 0 0 0 1 0
Maganese 0 1 0 0 0 0
Silver 0 0 0 0 0 0
Titanium 0 0 0 0 0 0
Potassium 0 2 0 0 0 3
Boron 1 0 0 1 14 115
Silicon 14 13 15 15 18
Sodium 11 19 18 6 2 6
Calcium 1252 1783 2165 1689 2582 3394
Magnesium 953 530 436 398 106 10
Phosphorous 932 796 816 754 680 764
Zinc 1025 974 1011 909 818 904
Barium 0 0 0 0 0 1
Properties
SUS Viscosity @ 210F: 58 66.2 66.4 64.4 64.8 57.8 [56-63] [58-65]
Flashpoint: 370 380 380 385 365 395 [>365] [>385F]
Fuel %: .5 TR .2.3 .5 1.0 .5 [
Antifreeze: 0 0 ? 0 0 0 [0]
Water: 0 0 0 0 0 0[
Insolubules: .3 .4 .2 .5 .4 .5 [
Code:
Air filter: OEM
Oil filter: OEM
Lead 2 3 3 3 2 2
Tin 0 1 0 1 0 0
Nickel 0 0 0 0 1 0
Silver 0 0 0 0 0 0
Barium 0 0 0 0 0 1
Properties
Water: 0 0 0 0 0 0[
