Code:
OIL 300V 5w30
MILES IN USE 2564
MILES 65175
SAMPLE TAKEN 9/24/11
ALUMINUM 9
CHROMIUM 0
IRON 8
COPPER 6
LEAD 0
TIN 0
MOLYBDENUM 578
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 40
SILICON 13
SODIUM 5
CALCIUM 1580
MAGNESIUM 869
PHOSPHORUS 867
ZINC 984
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 385
SUS VIS 210ºF 64.0
cSt @ 212ºF 11.33
TBN 6.0
Comments:
Thanks for the notes. Wear metals did increase a little in this sample, possibly due to a
combination of the longer oil run and your track events. Aluminum is twice universal averages, so it got a
highlight, but we're definitely not calling a piston problem just yet. You mentioned a lot of WOT, so that might
explain the aluminum. The viscosity was a little thick for 5W/30. The oil may have seen some heat, but the
slight thickening shouldn’t hurt anything. The TBN was strong at 6.0. Change this oil out due to aluminum
and check back in another 3,000 miles or so.
Here's what I wrote to Blackstone:
Sample was pulled after 100 mile highway drive at fairly constant speed. Car is driven aggressively and sees WOT regularly. Has also been to one half-day track event and four autocrosses on this fill of oil.
Car is not a daily driver and sits for 5+ days in a climate controlled garage. Driving is 75% city (predominantly “big city”, very slow stop-and-go) and 25% short highway (
Engine air filter was changed approximately 600 miles ago with OEM Hengst paper element. Redline SI-1 fuel injector cleaner was added at the same time. No other maintenance has been performed since this oil was put into service.
Oil capacity is 9.6 qt. Oil filter is OEM Hengst paper “cartridge”. Typical change interval is 5000 miles, which works out to roughly 8-9 months for me, hence the 2500 mile “half-way” sample.
I've had the car for two years and I keep seeing this "high" aluminum. I'm getting nervous that there's excess wear at the pistons or something (the block is Alusil, an aluminum-silicon mix). The last "halfway" sample I pulled showed half the aluminum but it was a thicker 300V 5w40 with more boron (4T moto oil). My very first UOA was a 5,000 mile OCI of Lubro-Moly Synthoil Premium 5w40 and it showed identical aluminum wear to my last UOA of Motul 300V 5w40. So regardless of how I drive or the oil I run, Blackstone always flags my aluminum numbers.
A very tiny percentage of these motors develop problems with scored cylinder walls and high oil consumption, but my car drinks about 0.5-1L between changes and has since the day I bought it. Those with problems see 1L per 1000 miles or worse.
Thoughts?
OIL 300V 5w30
MILES IN USE 2564
MILES 65175
ALUMINUM 9
CHROMIUM 0
IRON 8
COPPER 6
LEAD 0
TIN 0
MOLYBDENUM 578
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 40
SILICON 13
SODIUM 5
CALCIUM 1580
MAGNESIUM 869
PHOSPHORUS 867
ZINC 984
BARIUM 0
INSOLUBLES 0.2
WATER 0
FLASHPOINT ºF 385
SUS VIS 210ºF 64.0
cSt @ 212ºF 11.33
TBN 6.0
Comments:
Thoughts?
