There are a couple setups that you could build depending on the fittings you buy. Frantz sells an adapter to tee inline with the transmission oil cooler hoses. This adapter, similar in functionality to the Amsoil dual remote housing discussed a few threads back, causes a pressure drop across the hose by using a flow restrictor. The adapter itself serves as a flow restrictor. This pressure difference is then used to "feed" the Frantz or Motorguard with a pressure source and drain. No separate flow restrictor orifice is connected to the filter inlet. The only drawback of this is that it restricts flow to the tranny cooler somewhat.
If you have an transaxle temperature sensor (TTS) bolted to the side of the transmission you might be able to get an adapter to tee off of it - but you'll need to calculate the approximate flow restrictor that you'll need. The advantages of such a setup would be no reduction in oil cooler flow (safer) and perhaps easier to control the pressure inside the filter. The car that I have has a TTS that has a 1/8" NPT thread. You may have to borrow a TTS that corresponds to your car's make and model then take it to a hardware store to find it's thread size. Thus you could tee off of this port, add a flow restrictor to one end and run that (through a hose) to the bypass filter. As the drain, perhaps tapping the top of the throttlebody plate would do. From an engineering student's point of view, the 1/16" restrictor orifice allows too much flow to the bypass filter because there would then be more ATF flow compared to engine oil flow. This would cause too much of a pressure drop across the Filter and the canister would then pop or leak excessively. How much MORE ATF flow would there be compared to 5W30 flow using the same orifice? I use Mobil1 ATF. After reading the datasheet on Mobil's website it says that the viscosity of its ATF is approximately 1/3 that of Mobil 1 5w30. Also, the maximum pressure that is found at the TTS is 160 PSI. Because flow is inversely proportional to viscosity and directly proportional to the square root of the pressure, I found that the required flow restrictor must be approximately four times as restrictive as the 1/16" restrictor orifice. Thus I would need a 1/32" restrictor orifice because flow is proportional to the square of the orifice diameter.
Flow Equation
flow at fixed temperature = (some constant) x(square root of max. pressure) x [(diameter of orifice) ^ 2] / (viscosity)
This is an example of my car (Saturn '95 SL2)
The maximum pressure found at the oil pressure sender of the engine is 60 PSI. The maximum pressure found at the transaxle temperature sensor is 160 PSI.
Through a 1/16" orifice, the Flow of Mobil1 5W30 versus the flow of Mobil1 ATF at 100 degrees C is:
Flow of motor oil = K x (square root of 60 PSI) x [( 1/16" ) ^ 2] / (motor oil viscosity)
compared to ATF:
Flow of ATF = K x (square root of 160 PSI) x [( 1/16" ) ^ 2] / ( viscosity 1/3 that of motor oil)
= 4.89 times that of motor oil flow
Because the flow of ATF is 4.89 times the flow of 5w30 for a 1/16" flow restrictor, the flow restrictor would have to be smaller in diameter. Take the square root of 4.89 = 2.2. Thus in order for the flow of ATF to be the same as the flow of motor oil, the diameter of the flow restrictor orifice for ATF would have to be 0.0282" (about 1/32") or 2.2 times smaller than the flow restrictor used for motor oil.
[ June 09, 2005, 05:22 PM: Message edited by: mjo ]
Flow Equation
compared to ATF:
