Motorcraft FL600
Milano,Italy
Hello,if you know the Motorcraft oil filter "FL600",is a good filter? Use this to my focus here in Italy when it was new.
Thank you.
Originally Posted By: ctc
Where is it made?
I remember when I look, it is marked FO.MO.CO. (Ford Motor Company), then I think it is done in USA. According to you, these filters ford, or are of poor quality
It's probably of decent quality, manus. It may or may not be of US origin ..but so what? Europe has fine filter manufacturers.
Ok, thanks Gary. I just tried the filter on the country of production but there is nothing written, only "fo.mo.co.EFL600"
GENUINE FORD OIL FILTER
EFL600
FITS THE FOLLOWING VEHICLES AND ENGINE TYPES
ESCORT ALL 16V ZETEC'S
MONDEO MK 1 & 2 (1993-2001)
1.6/1.8/2.O 16V ENGINES
FOCUS MK 1 AND 2 (1998-2005)
1.6/1.8/2.0 ZETEC 16V ENGINES AND ST170
KA 1.3 8V DURETEC
This number helped get some hits on google
978M6714B2A
It appears to fit Festiva and Focus in Oz (AU).
If you're confident it is a genuine aftermarket OEM part, then I would not doubt the quality of it. Ford is pretty anal about their oil filters ..at least in the USA.
Exact Gary! The filter is just right! I always buy from authorized Ford dealer, so it's original OEM for sure. Thanks anyway.
that part number is interesting. 6714 is a base number for an oil filter usually used on farm equipment. the new FL-500S has that base number as well. most ford filters used in the US use the 6731 base number. the FL-820S for example has a real part number of F1AZ-6731-BD
That filter appears to be the same as the U.K. built Ford filter which is installed in many 2.0L and 2.3L Ford Focus engines.
