Hello Friends
I recently purchased a 2015 F150 Supercab 4x4 with the 3.5 V6 non-turbo engine. The truck had 190k on the odometer. I replaced spark plugs and ignition coils due to acceleration issues and misfire codes. When I removed the plenum I saw lots of oil in the plenum, and the PCV valve was clogged with sludge. Further inspection showed lots of sludge in the engine as well.
I performed the BG dynamic engine flush. I took some photos but not enough. The first few are the motorcraft which had motorcraft 5w20 for approximately 200 miles. The next two filters are two Champ PH500XL. The first one was run for 45 minutes at 3000 RPM with the engine cleaner. The second one was run for 20 minutes at 3000 RPM with the rinse oil.
I am pleased with the construction of all three filters. Interestingly, the motorcraft had the most sludge even though it was just regular oil.
Sorry for the long post enjoy the pictures I did take.
Thanks.
Thanks.
