Motorcraft Dark Green Replacement
Oklahoma
I'm going to be changing the antifreeze in a 2011 Ford Flex. Is there an aftermarket antifreeze that I may use in place of the original dark green antifreeze?
Several available for Specialty Green (Asian PHOAT). Least expensive currently PepBoys OEM brand Concentrate. Available either from PepBoys at ebay $17.67 delivered. https://www.ebay.com/itm/OEM-Concentrate...=item25cef6f756 Or in PB store if they stock it locally, $14.90.
Also Pentosin/Pentofrost A2.
If doing a complete flush and don't mind changing the tint, Walmart Valvoline Asian Vehicle premix.
My first choice would be the PB OEM Concentrate, green tint.
Originally Posted By: DBMaster
Originally Posted By: Schuttwegraeumer
There is a Ravenol FL22:
http://www.ravenol.de/en/products/usage/...green-konz.html
Ravenol also offers Mazda ATF FZ coolant. Interesting.
I meant ATF FZ transmission fluid. It's interesting because there is no generic ATF in the US compatible with ATF FZ yet. It appears that in other countires you can get generic FZ AND FL22.
