Any thoughts of mixing Motorcraft 5-20 with Motorcraft 10-30 (50/50). I got a 98 Ford Taurus and it calls for 5-30. Would that combo work since the 5-20 seems to be the norm for the newer Fords. Any comments would be appreciated.
quote:I'm curious - what is a "forged engine"? Thanks.
Originally posted by mf150: several 4.6L Mustangs (GTs) have blown engines on the 5W-20 weight viscocity. My pal was rhomping on the gas when all of a sudden, bang bang bang bang...rod knock, and now he's buying a forged engine.
quote:To mf150: Any idea what brand(s) 5W-20 was used in these engines that are are failing? One would think that Motorcraft 5W-20, which is partially synthetic and not that much thinner @ 100 C than M1 5W-30, would be able to handle pretty heavy loads. Thanks.
quote:My guess is it isn't the oil that's causing these engines to blow. 5W-20's are dam good oil.
Originally posted by mf150: several 4.6L Mustangs (GTs) have blown engines on the 5W-20 weight viscocity. My pal was rhomping on the gas when all of a sudden, bang bang bang bang...rod knock, and now he's buying a forged engine. I'd stick with a Xw-30 weight in the newer Ford modulars.
quote:The rods from the factory are not forged. they are melted and pressed powder, so, too are the pistons. These factory internals are good to the 400 HP mark.
Originally posted by JustinH: forged engine means a shortblock is built up using stronger parts that are made through a forging process, and not a cast process. Technically the 4.6 has forged rods from the factory, they are toothpicks though, the manley forged rods are much thicker.
quote:Motorcraft 5W-20 was in my pals engine that blew a rod. His 2002 Gt was serviced at the local Ford dealer. The other couple engines were also run on 5W-20 viscocity...not sure what brand. Before the switch to Motorcraft 5W-20 viscocity, I have never heard of a 4.6L blowing rods. The facts are the facts, and Mobil 1 5W-30 is a 30 weight.
Originally posted by pmt:quote:To mf150: Any idea what brand(s) 5W-20 was used in these engines that are are failing? One would think that Motorcraft 5W-20, which is partially synthetic and not that much thinner @ 100 C than M1 5W-30, would be able to handle pretty heavy loads. Thanks.
quote:No-one is saying that 5W-20 blew the engine, but it is coincidental that 5W20 has been in a few engines (Ford 4.6L SOHC)when the con. rods. failed. The 4.6L triton/SN-95 GT engines are known to be bulletproof performers. These are the first 1999+ 4.6Ls that I have heard any problems about. A 4.6L Mustang engine can run safely up to 400HP, after which point you would need to upgrade to forged internals. If the GTs, naturally asperated, aren't hitting the 400HP mark, then why are the rods failing and the engines blowing? could it have to do with lubrication??? What do these engines have in common? 5W-20 anyone? Especially since I haven't heard of many engines before the switch to 5W-20 blowing.
Originally posted by Fred Bear: With M1 5W-30 so close to a 20 weight. I find it hard to believe the 5W-20 "blew" an engine.The engine had to have other issues. Ford would not spec an oil that would come back and bite them in the butt!!
quote:10W-30 is a **** good oil, so is 5W-30, so is 10W-40, so is 15W-50, so is 20W-50, so is 15W-40, so is... catch my drift?
Originally posted by bottgers:quote:My guess is it isn't the oil that's causing these engines to blow. 5W-20's are dam good oil.
