The 3.7 has an internal water pump. Watch for a small coolant leak at the water pump leak hole. A you tube video will show you the exact location to watch for. If the internal water pump seal fails completely, it will dump coolant into the engine. Check under the intake manifold for a leak at the coolant crossover tube, those o-rings have been known to fail also.
