MAKE/MODEL: Nissan 4.0L V-6 VQ40DE
OIL TYPE & GRADE: Motomaster Syn 5W/20
OIL USE INTERVAL: 10,700 KM - 11 MONTHS
OIL MM5w20 UNIVERSAL AVG
KMS IN USE 10300 9100
KMS 81000 -
SAMPLE TAKEN 3/27/12 -
ALUMINUM 4 4
CHROMIUM 1 1
IRON 22 11
COPPER 20 8
LEAD 3 3
TIN 0 1
MOLYBDENUM 55 77
NICKEL 0 0
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 2 2
BORON 10 46
SILICON 18 18
SODIUM 0 37
CALCIUM 2206 2371
MAGNESIUM 10 80
PHOSPHORUS 636 679
ZINC 656 806
BARIUM 0 0
INSOLUBLES 0.4
WATER 0
FLASHPOINT ºF 405
SUS VIS 210ºF 53.0
cSt @ 212ºF 8.17
FUEL ANTIFREEZE 0
TBN 3.1
COMMENTS: Copper and iron were a bit elevated in this first sample, but other elements look good. Averages show expected wear for this engine after 9,100 km on the oil. Your oil run was a little longer, but it probably wasn't long enough to explain the extra iron and copper. Iron shows wear at steel parts and copper comes from brass/bronze. Maybe they're accumulated from long runs -- that's entirely possible. For now they're just something to watch. They may end up being no problem at all. The TBN was fine at 3.1. No fuel/coolantfound. Try 10K miles again to monitor.
Thoughts? The truck is a short trip daily driver. 5.5 miles one way. The oil is holding up very well for being in an engine spec'd for 30 weight oils.
I did mess up the sample and took it almost instantly after I opened the drain plug, hopefully that didn't throw any numbers off.
KMS 81000 -
ALUMINUM 4 4
CHROMIUM 1 1
IRON 22 11
COPPER 20 8
LEAD 3 3
TIN 0 1
MOLYBDENUM 55 77
NICKEL 0 0
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 2 2
BORON 10 46
SILICON 18 18
SODIUM 0 37
CALCIUM 2206 2371
MAGNESIUM 10 80
PHOSPHORUS 636 679
ZINC 656 806
BARIUM 0 0
INSOLUBLES 0.4
WATER 0
FLASHPOINT ºF 405
SUS VIS 210ºF 53.0
cSt @ 212ºF 8.17
FUEL ANTIFREEZE 0
TBN 3.1
