Hi,
Has anyone tryed this MOTIP EGR/TURBO cleaner?
Is it working? I found video on yt how to use it. https://youtu.be/Dbl35180i4Y
If I have understood video good, I have to disconnect the manifold apsolute pressure sensor, and when spraying into the intake tube, and not spray at MAF sensor. When I dismount the MAP sensor from the intake do I Leave it plugged in cable just not connected on intake tube or what? When I start the car with unplugged wire on MAP sensor it does not run fine.
