Originally Posted By: PimTac
I have read a lot of comments here and on other sites regarding GDI or TGDI engines and how to counter carbon buildup. To condense it all in one post;
Run the manufacturers specified oil and find one with low Noack, low calcium which equates to gen 2 dexos. Change that oil regularly. In other words don’t skip oil changes.
These engines like to be wound up. Take the vehicle out once a week and enjoy a spirited drive.
Use top tier fuel. I have also read and heard that using premium may help with fuel dilution of the oil. On a side note, my Mazda SkyActiv 2.5 hit the half tank mark from what the dealer filled it with. I filled it with Shell V-Power. Now, according to many here, I should not notice any difference but I did right off the bat. Better acceleration. Also, with no change in city/highway driving ratio, my mileage went from 24.2 to now 26.3. Was it the fuel? I can’t say for certain. Since this is totally non-scientific , it’s only my word against everyone else. The engine should adjust for the octane but maybe there is something here we do not understand fully.
Enjoy the new GovMo. Sounds like a real fun car.
I have to agree with you. My Impala is DI. I have noticed that running premium or 89 octane, the oil level drops slightly. On oil changes where I run only 87, the oil stays or increases from where it started at the last oil change (full line).
I have also monitored the fuel trims and I have seen a pretty big difference between running 87 and 91 octane. The fuel trims are much lower and more into the negative numbers with 91, and the I've also seen the MPG increase with 91 octane. Not a huge amount, but about 1 - 1.5 MPG. I drive the same route 5 days a week, about 16 miles each way.
As far as deposits, I haven't looked at the valves, but I have noticed no performance problems and the MPG is just as good or in some cases slightly better than when I bought it. The car was less than 2 years old with about 20K miles on it. I'm currently almost to 80K miles.
I am very happy with my direct injected engine, and would buy another one in a heart beat.
FWIW, with the exception of the first couple of oil changes done at the dealership, I have used Pennzoil Platinum 5W-30, and Mobil 1 5W-30 with the exception of last fall before one our 3,000 mile round trips when I picked some Pennzoil Platinum 10W-30.
