AMSOIL and Redline are the only ones that I'm aware of publishing their NOACK numbers. I think even Valvoline has mostly withdrawn them from their PDS. I think there are some Castrol PDS that have NOACK but those might be old formulations and not what is on shelves.
On the recent study that I saw, it's confusingly not straight forward what kind of oil can leave deposits. My only takeaway from that study was to change your top tier oil very frequently. Valve intake deposits seem to contain oil additives so it's not purely from combustion blowby. It seems oil vapor is depositing onto the intake valves themselves exacerbating the problem.
So if you want to try to minimize deposits between cleanings to maintain efficiency, reliability, and performance... the only clear thing to do in my view, is to frequently change as low NOACK oil you can find for your uses. For me, I'm planning to keep using Castrol 0w40 (which might not be good for turbo GDI due to 2k+ Ca) at 5k intervals. Redline 5w40 is 3% lower in NOACK but it's my theory that it's better to run Castrol 0w40 at 5k than Redline 5w40 at 10k in regards to valve deposits.
