Sometimes you just can't win. I usually have a rule of no pad slaps. Usually I do a minimum of replacing the caliper with the pads. Here in NY, once the pistons extend, the salt spray still works its way in and as soon as you put in a new set of pads you end up with the bakes dragging all the time. Rotors -- usually I can get 4 or 5 years out of them before they need replacing.
So I bought some nice high end pads for the Subaru. Put them in after cleaning up the rotors a bit. Went for a drive. Biiiiiiiiig smoke show. Let the car cool down , verified that the pads were the correct one (I initially thought they were not). Saw that it was some rust around the edge of the rotor that was causing the pads on the LF to drag. So I took the rotors off, Wire wheeled them up, then threw them back on and went for a test drive. A little longer of a test drive.
LOTS of smoke. It got real hot. Ordered new rotors at that point ... not cheap rotors, nice coated / painted ones from Rockauto, with expedited shipping. Still cheaper than anywhere else.
Last night I went to throw the new rotors on. It got so hot, the seal on the LF unit bearing failed and let a lot of grease out. It also melted the caliper boots -- to the point that one piston doesn't even have one any more!
So , calipers are going to be around $140 plus another $10 in fluid.
Timken wheel bearing $122
