2013 Fiesta Hatch SE 5 Speed Manual. 61,554 miles.
Iron PPM jumped from 5 to 11 at last 6000 mile oil change.
5,986 6 PPM
5,964 5 PPM
6,179 11 PPM 61,554 8/14/2020 oil added 0
I was told that's only 1 PPM over average, so I am not worried. "Often iron will fluctuate based on operational conditions, so maybe you did some more idling between last oil change and now, or maybe you did more stop-and-go driving. Whatever the cause, the change in
iron is not a major issue"
I can not remember any change in my driving behavior. Since Covid 19 the car has been sitting unused a little more.
Where would Iron be coming from? I am guessing Cylinder walls if the aluminum block has sleeves, valves and stems, piston pin, camshaft, or oil pump. Don't think crankshaft as bearing material would be showing up.
5,986 6 PPM
5,964 5 PPM
