Jeff..... just 1 if it is set correctly. We think if we get solid rods of the different sizes to use as a set up gauge it will speed the set up. The tube shown is -4 1/4" and we are 1/2 turn past straight through. In tube bending you always have to allow for what is called spring back which is more than likely why we have to go a hair past straight through to make it straight. I'm also fairly sure that this will also change when we start working with the stainless.
