Some of you may remember me saying I was going to run synthetic oil in my RX/7 even though many said not to. Well, after putting 5,000 miles on the oil I changed it last weekend. The plugs were walnut blasted before I changed the oil as I wanted them to be real clean so I could tell how they would last with the synthetic as far as carbon build up. This car goes through plugs like I change my shorts, every 10,000 you HAVE to change them. Well, there was about 3,500 miles on them when I changed the oil to mobil 1 15W-50, When I took them out to look at them they were carboned up worse than they have ever been. I would have thought that because synthetics generally have a low % of ash, that they would have been cleaner than when I was running dello 400.
The car ran fine durring the 5,000 miles actually I think better than before, but It was starting to miss because of the carbon on the plugs towards the end.
The car is an 87 with 285,000 miles, maybe it`s time for new injectors and the carbon is from fuel.
