Monitor shows (disks 100%)" Win 7
los angeles
Recently I have noticed that a cpu/disc/ram monitor that I have installed months ago, is now showing Disks 100%, whenever I start computer.It does take quite a bit longer to open a browser. It does go to desktop. if I go to Task Manager,it doesn't show anything except if I have a window open. i have also went to Msconfig and turned off as much as possible under startup. what else can I check? Win 7
Great Lakes
If by "Disks 100%" you mean that your hard drive is full, then this has nothing to do with the startup processes you turned off in msconfig. You need to delete some stuff from your hard drive. Click the "Computer" icon. What does it say about the capacity of your hard drive(s)?
daves66nova
los angeles
Its states 66gb free of 148. After about 10 minutes, it drops down to 10% or even to Zero, then it starts to work great again.
Zimbabwe
He means active disk usage is 100%. It's loading programs and stuff. First, open the start menu and search for and run "disk cleanup" and check every box to clean up some junk. Then, open "programs and features" from the control panel, and remove any programs you're not using. Try to be as aggressive as you can here. Even if you think you might use a program some day down the road, go ahead and remove it to free up some of the space. More used space = more time to start the same programs that would take a few seconds on a nearly empty disk. Another thing you can do is either run the built in defragment program, or I recommend iobit Smart Defrag, which has options to prioritize files so the most used files are on the edge of the disk where the surface speed is faster, so files can be accessed a bit quicker. Do not do this if you have a solid state drive. iobit and I think windows (maybe) will warn you not to do it if it's an SSD
Zimbabwe
Originally Posted By: KrisZ
How is the CPU usage? You may have malware or some other virus causing the system strain.
With 148GB I'd imagine it's just an old slow drive and computer, more likely than malware I'd figure.
daves66nova
los angeles
CPU is always very low, around 20% more or less.
daves66nova
los angeles
HDD,mobo are only about 3 years old.
daves66nova
los angeles
I think it's fixed now. I looked into Avast! and Malwarebytes settings and MB has a startup check setting. I turned that off and it seems to be alright now. Thanks to all for the suggestions!!
