yours is a very different situation, but note that all cars with oil starvation problem on track do eventually experience engine failures. there might be some that were raced only once or twice without problems, but any car raced regularly (especially on race tires) that sees zero oil pressure at some point on track, will have problems.
it's interesting to see what cars can handle this duty with stock oiling systems. i have often wondered if it's a coincidence, or if the manufacturer specifically designed the system to handle that usage.
and for the cars that can't handle it, it makes me wonder what kind of testing was done. i had always assumed every manufacturer flogs their test mules around racetracks, but maybe they don't.
fwiw, the later C4 corvette oiling system is one of the good ones. it has baffling in the pan, a windage tray that is part of the engine but integrates with the baffling in the oil pan, and a very nice pickup tube that has a gentler bend and larger diameter than sbc stuff of yore. i have seen more oiling problems on those cars with aftermarket racing pans than with the stock system!
-michael
