On another forum these statements are being made. Any truth to them? I do not remember hearing any of this.
"I use there gear oil,good stuff and haven't had any problems.I wouldn't recomend using the engine oil since it has a high moly content which is bad for our tighter tolerance engines".
"I quit using their motor oil when i read about the moly. Performed just fine but moly builds up after years of use and I didn't want to take the chance".
"Moly is a processed mineral that is similar in appearance to graphite. Moly has good lubricating properties when used either by itself (in dry power form or as an additive to oil or other lubricants). Particles of the Moly can come out of suspension and agglomerate. Over time this may actually clog or partially clog oil filters or oil lines and the remainder normally settles in the bottom of the oil pan. This seems to be more likely when using extended drain intervals".
