Modern ATF's
MolaKule
Staff member
Iowegia - USA
Analysis Courtesy of Dyson Analysis
Analysis performed 3/2003.
Oil Brand/Weight : Blend of PAO/Group I, II ATF
Dexron III/Mercon Compatible
Type Equipment : Clean
Miles/Hours on oil : Clean
Total Miles/Hours : Clean
Results ppm/% Comments (blank=normal)
Wear
Copper 0
Iron 1
Chromium 0
Lead 0
Aluminum 0
Silicon 2
Tin 0
Additives
Molybdenum 1
Sodium 7
Magnesium 1
Zinc 8
Potassium 0
Phosphorus 247
Calcium 214
Physical Properties
Sulfur NA
TBN 2
Vis@100 C (cSt) 8.5
TAN 0.5
Iron from [pipe] corrosion. nothing really stands out to me.
Oil Brand/Weight : Full Synthetic ATF
Wear
Copper 0
Iron 1
Chromium 0
Lead 0
Aluminum 0
Silicon 4
Tin 1
Additives
Molybdenum 0
Sodium 6
Magnesium 1
Zinc 3
Potassium 0
Phosphorus 255
Calcium 224
Physical Properties
Sulfur NA
TBN 2
Vis@100 C (cSt) 8.5
TAN 0.2
Final Comments : nothing out of ordinary
Mola's Comments: This analysis doesn't show the Sulfur, Nitrogen, or Boron additive components, nor the base oil's, but does give one baselines for comparison to future UAO's.
[ March 25, 2003, 07:02 PM: Message edited by: MolaKule ]
Since the Zn is so low what compound is the Phosphorus in?? Obviously not ZDDP
[ March 26, 2003, 08:23 AM: Message edited by: Al ]
Al,
It actually is the ZDDP.
Additive suppliers can give you ZDDP with greatly varying amounts
of zinc, phosphorus, and sulfur.
