Your thoughts?
Analysis by Blackstone...
Thanks!
Comments:
It's another good report for your Audi. This oil was run just under 6,000 miles, but you couldn't tell it by looking at wear. All wear either held steady or improved over what we found last time and that is an excellent sign that no problems are developing. We did fine a trace of fuel, though that's not what we would consider a problem level and it should take care of itself next time. The viscosity was again slightly low, but a little better than what we have been seeing. The TBN was strong at 4.5, so active additive held up nicely. Try 8,000 miles next oil.
Code:
OIL M1 0w-40 M1 TDT 5W-40 M1 TDT 5W-40
REPORT DATE 08/03/09 10/22/09 12/03/09
MI/HR on Oil 5239 4550 5994
MI/HR on Unit 46387 54303 60297
Sample Date 07/29/09 10/03/09 11/14/09
Make Up Oil 0 qts 0 qts 0 qts
ELEMENTS
IN PARTS PER MILLION
ALUMINUM 2 2 2
CHROMIUM 0 0 0
IRON 28 11 10
COPPER 2 2 2
LEAD 1 0 0
TIN 0 1 1
MOLYBDENUM 70 17 3
NICKEL 1 1 1
MANGANESE 1 1 1
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 2 1 1
BORON 113 50 30
SILICON 3 2 2
SODIUM 56 8 9
CALCIUM 2561 1335 1217
MAGNESIUM 42 629 765
PHOSPHORUS 806 916 854
ZINC 1000 1089 992
BARIUM 0 0 0
PROPERTIES
SUS Viscosity @ 210°F 63.0 63.0 64.2
cSt Viscosity @ 100°C 11.06 11.07 11.39
Flashpoint in °F 390 385 370
Fuel % 0.5 0.5 TR
Antifreeze % ? 0.0 0.0
Water % 0.0 0.0 0.0
Insolubles % 0.3 0.3 0.2
TBN 6.7 6.0 4.5
Additional Information
Iron per 1000 miles 5.34 2.42 1.67
Thanks!
Comments:
Code:
ELEMENTS
ALUMINUM 2 2 2
CHROMIUM 0 0 0
IRON 28 11 10
COPPER 2 2 2
LEAD 1 0 0
TIN 0 1 1
MOLYBDENUM 70 17 3
NICKEL 1 1 1
MANGANESE 1 1 1
SILVER 0 0 0
TITANIUM 0 0 0
POTASSIUM 2 1 1
BORON 113 50 30
SILICON 3 2 2
SODIUM 56 8 9
ZINC 1000 1089 992
BARIUM 0 0 0
PROPERTIES
Fuel % 0.5 0.5 TR
Water % 0.0 0.0 0.0
TBN 6.7 6.0 4.5
