Your Thoughts?
Code:
OIL Mobil 1 TDT 5W-40
REPORT DATE 10/22/09
MI/HR on Oil 4550
MI/HR on Unit 54303
Sample Date 10/03/09
Make Up Oil Added 0 qts
Comments:
You shortened your oil use to 4,550 miles and there was a significant improvement in iron,
which comes from steel parts. All of the wear metals in this sample read below universal
averages and were in balance to one another indicating normally wearing parts at 54,303
miles. The oil's viscosity was a little low again measuring in the SAE 30W range. No gasoline,
moisture or any signs of anti-freeze were present in the sample. The TBN was 6.0, this
time. Sodium also dropped to a reasonable 8 ppm. All in all, a good report. Try ~6,000 miles
for your next sample.
ELEMENTS
IN PARTS PER MILLION
ALUMINUM 2
CHROMIUM 0
IRON 11
COPPER 2
LEAD 0
TIN 1
MOLYBDENUM 17
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 50
SILICON 2
SODIUM 8
CALCIUM 1335
MAGNESIUM 629
PHOSPHORUS 916
ZINC 1089
BARIUM 0
PROPERTIES
SUS Viscosity @ 210°F 63.0
cSt Viscosity @ 100°C 11.07
Flashpoint in °F 385
Fuel %
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.3
TBN 6.0
Additional Information
Iron per 1000 miles 2.42
Code:
MI/HR on Oil 4550
MI/HR on Unit 54303
Comments:
ELEMENTS
ALUMINUM 2
CHROMIUM 0
IRON 11
COPPER 2
LEAD 0
TIN 1
MOLYBDENUM 17
NICKEL 1
MANGANESE 1
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 50
SILICON 2
SODIUM 8
CALCIUM 1335
MAGNESIUM 629
PHOSPHORUS 916
ZINC 1089
BARIUM 0
PROPERTIES
Fuel %
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.3
TBN 6.0
