Originally Posted By: Ven
It wasn't "back flushed". The fluid was exchanged without intervention other than T'ing a cooler line. The trans pump does most of the work at idle. It's still closed loop circulation, only now the output fluid is binned and the input fluid is new. The transmission doesn't experience anything different, or is under any different conditions than if it were idling in my driveway.
Maybe, just maybe, if I had some old abused crusty trans that has been neglected and never serviced, I could see the strong detergents of newly introduced ATF possibly dislodging building up or crud sediment that could block or restrict passages in the valve body. But this isn't the case on my low miles, don't tow, always clean fluid truck. The flush has nothing to do with it, I'm certain the fluid used does.
Your problems are a mystery my son.
