shinerburke, as
eljefino said, it might have been only momentary loss of oil pressure for the short time the oil light was on. Without knowing the actual pressure, it’s hard to say. But, if there is no knocking, I doubt you did any harm. I
would however, change the oil again fairly quickly. If this thing was running on just 1-2 quarts of oil for a while, that stuff was put through **** and I’d get rid of it ASAP.
Ever consider doing a UOA (used oil analysis) for $20 on a sample of that oil? That would tell you if had any increased wear and whether you might want to bite the bullet and get rid of the vehicle earlier than you would like. Blackstone Labs has a link on this site. Try their basic service. No need to spend an additional $10 on TBN testing. Post the results on this site and I’m sure you’ll get comments just like this thread has gotten a fair amount of posts so far.
So what caused the consumption? Hard to say but the first thing I’d do is check the oil filter and make sure it didn’t loosen. That happened to me once in a car which had never burned any oil but was suddenly down a bit. Oil filter was a little too loose and was dripping oil very slowly. Other theories about cleaned ring packs, etc … are worth considering as well.
As for your current course of action, using Pennzoil High Mileage Vehicle oil makes perfect sense. It’s actually a sort of synthetic blend (includes 10-15% ester, Group V synthetic) with a potent additive package and isn’t too expensive. I also like the regular Pennzoil as well as Chevron (if it’s available in your area). Both are very good Group II+ base oils, the best available among the major brands. You won’t find the anti-Pennzoil bias (“too much wax,” etc …) on this forum too much. We know better than that.
As for dealing with the rest of the family/in-laws, that’s another problem. I know how guilty you feel. Several years ago I was checking and topping off a woman’s car and I left the oil filler cap off by mistake. She called 30 minutes after she left the house and complained of a smell and smoke coming out from under the hood.
No real harm done. The cap was stuck in a corner of the engine compartment and the car lost less than 1 quart of oil … but I felt guilty … and like a total idiot.
I think you should forget about synthetics for a while. The Group II+ oils are very
very good, anyway. Enough of your family is gripped in the anti-synthetic myths and the slight benefits are not worth the hassle. Given what has happened, I’d feed the RAV a steady diet of one of the Pennzoil formulas until your wife completes her post-graduate work and you’re ready to trade it in.
Best of luck,
Bror Jace
