I have a 1997 Toyota Rav4 with the 3SFE engine that has about 207k miles. Since I bought it, I was told by the previous owner that it burns a little oil, which is expected for the age and mileage. I also found it was leaking oil at the crank and cam seals, so I went ahead and did a new timing belt/water pump and did all the seals while I was in there.
Since I bought it I did a Kreen treatment and ran it for roughly 1000 miles with great results, oil was pitch black. After that I proceeded to run 2-3 oil changes of the cheapest 5W-30 I could find at about 500 mile intervals.
Now that I'm clean, I did a change to Mobil1 High Mileage 5W-30 with a slightly taller Wix filter which gives me roughly an extra 1/3 quart of capacity.
I have put roughly 200 miles on it, and did a 70 or so mile round trip this past weekend. I've been making an effort to take it on extended highway runs since it mostly sees a city commute of 7 miles total a day.
So to the point, I checked the oil level this morning and it was slightly below the halfway dipstick mark. I topped it off with some more M1H1, but it took roughly 3/4 of a quart to do so. That seems like a lot of oil loss only 200 miles into the OCI. Previous OCI's of conventional oil required a half quart of so every 500-1000 miles.
Should I be worried or keep topping off the M1H1 and let it run it's course? I'm hoping the oil can help curb the burning and I planned on running the OCI to 3,000 miles if I can help it. No smoke on startup or any at all, for that matter. Car runs very strong and is healthy.
I appreciate the advice, thanks BITOG!
