Originally Posted By: daman
To save a little $$ one can run the truck & SUV 5w30,same add pack as the EP,better TBN i believe, and $22 vs $26 for EP.
Where do you have this knowledge of their mixture? I would be you are way off on this since their specs are different.
Mobil 1 EP: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil_1_Extended_Performance.asp
Truck & SUV: http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_Truck_SUV_5W-30.asp
From VOA's off this site..do a search.
Making others search in order to prove your point doesn't really do much for your side of the conversation. If you want to make a point, you should have the information ready to present. Otherwise you're just presenting a bucket with no water in it figuratively speaking.
Plus VOAs only test for certain known additives.
EDIT: So I thought I would spend time today looking for these VOAs with the same additive packages. You are mistaken daman. Check these links: http://www.bobistheoilguy.com/forums/ubb...true#Post772093
http://www.bobistheoilguy.com/forums/ubb...rue#Post1342568
They seem pretty different to me. Check your facts before you post something like that next time.
